vacuum leak
Old Jan 1, 2008 | 09:27 PM
ebcjlc's Avatar
ebcjlc is an unknown quantity at this point
Default vacuum leak
I have a 92 blazer, 350 TBI, I replaced the brake booster and Master cylinder in it. Upon doing so, everytime you step on the brake the engine revs up and then when you let off the brakes it does it again. The pedal will go down the floor (not easily) when the truck is on but not when it is off. I have bleed the brakes..... no air in the system. I repaced the new booster (Reman) immediately and the issue is still there. one way check valve is good.
Old Jan 1, 2008 | 10:42 PM
Chevy Lover's Avatar
Default RE: vacuum leak
Does it idle normal or high when it's in "P" with no brake applied?
Check the vacumm hose from the check valve to the intake manifold, both ends.
It doesn't seem right that the brake pedal goes to the floor unless you have air in the brake system or a faulty master cylinder.
Was the master cyl reman also?
Old Jan 2, 2008 | 10:45 AM
*Moving to Full Size Tech Section*
Old Jan 3, 2008 | 08:05 PM
ebcjlc's Avatar
The rubber hose and steel line are both good, no leaks from the fitting in the manifold and yes the Master cylinder is reman also,,,, brakes have been bleed three times and are air free.
cjb2145
18
Oct 6, 2018 04:46 PM
Jharper
Dec 19, 2007 08:47 PM
kfk4nf
Nov 2, 2007 09:59 PM
magnum434
Aug 15, 2006 12:39 PM
doom1701e
Sep 8, 2005 09:16 AM
