vent fan intermittent on 87 K5 Blazer - fixed!
Old Feb 14, 2009 | 01:32 AM
encryptedzion's Avatar
encryptedzion is an unknown quantity at this point
Default vent fan intermittent on 87 K5 Blazer - fixed!
For some reason, my vent fan works intermittently. I have tried all positions and fan speeds at different intervals. It just works whenever. I've checked the fuse as well. Iam beginning to believe it is just the age of the unit, along with wear/tear over time, that is causing my problem, and to have the unit replaced.
I would appreciate any advise or pointers if there is something else that could be the cause of my problem that I may be missing.
Thanks in advance!
Old Feb 14, 2009 | 07:39 AM
Bigringtravis's Avatar
Bigringtravis is on a distinguished road
Default RE: vent fan intermittent on 87 K5 Blazer
Not sure if this is exactly what you need but, here is the idea - Blower motor resistor:
http://shop.advanceautoparts.com/Pro...61&PTSet=A
Pretty cheap - I know I need a vacuum switch for mine!
Hope that helps!
Old Feb 14, 2009 | 01:10 PM
If it works intermittently, I would suspect worn brushes in the motor. If it is not working, will it begin to work if you hit the blower motor sharply?
Old Feb 14, 2009 | 10:32 PM
ORIGINAL: Bigringtravis
Hope that helps!
Where is this part located? Within the dash?
Old Feb 14, 2009 | 10:38 PM
ORIGINAL: swartlkk
I am suspecting themotor is worn and needs replacement due to age and wear/tear. Good thing the dash pad is original and cracked because I have hit it a couple of times to see if that gets the motor going. I have not hit the motor directly though. It just seems to work when it wants to if I hit the dash or not.
Old Feb 16, 2009 | 04:39 PM
Default RE: vent fan intermittent on 87 K5 Blazer - fixed!
I decided to replace the motor, since I had the time and the price for a new motor was only $20. I connected ground and power to the new motorbefore I removed the old one just to see if it worked. Presto! It worked great. So, I swapped the motors, reconnected ground and power, started the truck, andran the fan on different speeds using heat, A/C and defrost. Everything ran great! One of the retaining screwswas a little difficult to get to...but that's okay. Problem solved!
Thanks to everyone for their help!
cheesequaker
Apr 25, 2012 01:44 PM
aztcwrior25otvws25
Apr 23, 2011 12:12 AM
valeria1782
Jan 24, 2011 04:12 AM
jrpx2
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Aug 9, 2010 10:15 AM
upblazer95
Nov 16, 2008 03:20 AM
