Vibrations @ 50+
Old Jan 23, 2009 | 10:49 AM
scrmmealuvsong22's Avatar
scrmmealuvsong22 is an unknown quantity at this point
Default Vibrations @ 50+
In my 91 blazer fullsize when i get to 50-55 any speed above there when i let off the gas i get vibration that seem to be right between the front seats i was thinking it may have been my u joint on the front of my driveshaft since the rear joint is brand new. I was wondering if it could be anything else. Friends have been saying my it could be my driveshaft is tweaked???
any kinda of suggestions would help
Old Jan 24, 2009 | 08:03 AM
Default RE: Vibrations @ 50+
bump
Old Jan 24, 2009 | 08:15 AM
rriddle3's Avatar
Please have patience. It sometimes takes awhile for folks to get around to a question. You had a post a couple of weeks ago about breaking a yolk strap and dropping the driveshaft, right? If the shaft hit the road while you were moving, yeah that could damage the shaft and cause a vibration. I would check the u-joints for wear (if they're old, just replace them anyway) and inspect the driveshaft for damage.
Old Aug 17, 2009 | 06:20 PM
offskooring's Avatar
offskooring is an unknown quantity at this point
bump again
Old Oct 23, 2009 | 11:46 AM
Straka88's Avatar
Straka88 is an unknown quantity at this point
I have the same problem with my 88 BLazer, but I had just added a 4 inch lift. Was told it was the U joints but I haven't had it fixed yet. Let me know if you have fixed your problem or not. Hopefully it is just a U joint or two.
Old Oct 23, 2009 | 02:22 PM
abig84's Avatar
id guess u joints too. maybe a bad crossmember mount or a bent driveshaft may cause this
Old Oct 24, 2009 | 11:14 AM
steechfinger's Avatar
steechfinger is on a distinguished road
if your drive shaft hit the ground theres your problem its proably bent. hit the junk yard and get a new one and replace your u-joints. its not that hard or expensive
Old Nov 12, 2009 | 06:23 PM
Straka88's Avatar
Just changed out my U-joints and that seemed to fix my problem.
Old Nov 24, 2009 | 09:51 PM
nash_686's Avatar
nash_686 is on a distinguished road
I had this problem in my '91 K1500 Blazer. I replaced both U joints and it fixed the problem for about a month, then the problem returned. So I'm back to square one.
Old Nov 24, 2009 | 11:22 PM
BusaJoe's Avatar
BusaJoe is on a distinguished road
How often you go mudding? It could just mud in your wheels.
