wheel codes
Old May 7, 2007 | 12:35 PM
tom1337's Avatar
tom1337 is an unknown quantity at this point
Default wheel codes
Not sure if this should be posted here but my wheel code does not match any of the RPO codes. The code I have is JJ could anyone tell me what it means?
thanks
Old May 7, 2007 | 12:51 PM
Default RE: wheel codes
It might be a part identification code. I wouldn't think it would have much to do with the RPO code although there may be a list somewhere (internal GM) that states this RPO code gets these rims with this part code.
With multi piece steel rims (your pictures are a bit small in your gallery so I can't really tell what they are),You have 2 different pieces that make up the rim, the center section, then the hoop. It is possible that the JJ is the code for the hoop or centersection, depending on where the mark is located.
Also, this could be a date code or an inspector identification. Are there any other numbers on the rim?
Old May 11, 2007 | 07:17 AM
drperry's Avatar
Looks like you've got the Rally Rims...
The JJ code could be for different center caps... I.E: Bowtie, or 4x4, or GMC
Kilo
Jul 27, 2013 06:57 AM
abadinalbany
Apr 16, 2011 11:31 AM
bigjoewebb
Jan 27, 2009 09:36 AM
mikeesho1
Oct 26, 2007 12:31 AM
drperry
Jul 4, 2007 04:25 AM
