wont run
Old Jun 15, 2012 | 03:54 PM
pachino237's Avatar
pachino237 is on a distinguished road
Default wont run
replaced fuel pump,oil pressure/fuel senser rebuilt throttle body,replaced fuel relay still wont start and stay running unless u r pouring fuel into throttle body
Old Jun 15, 2012 | 04:00 PM
rexmburns's Avatar
Super Moderator
Have you done a pressure test on the fuel system? If not start there. Somewhere on here there is a good diagnostic thread for this. I'm on my phone someone help me find it please and post the link for him
Jamaroon's Avatar
welcome to the site, sounds like you need a new flux capacitor.....
you'll need to provide more infortmation about the vehicle before anyone will be able to help.
Old Jun 15, 2012 | 04:11 PM
rexmburns's Avatar
Super Moderator
Haha good call jam I didn't even think of that silly mobile version doesn't show all the info. Thanks for havin my forgetful back on that one!
Old Jun 16, 2012 | 09:38 PM
THePaRaSiTE5771's Avatar
THePaRaSiTE5771 is on a distinguished road
Maybe bad injectors? Also, when you turn the key to the "run" position, after the fuel pump runs do you hear any gasoline moving or spraying around in the tank?
Old Jun 17, 2012 | 08:51 AM
JDrummond Service Inc.'s Avatar
JDrummond Service Inc. is on a distinguished road
Welcome... really need more info to help. 4.3 2.2? TBI? did you replace your filter?
Old Jun 28, 2012 | 11:02 PM
Nak's Avatar
Nak
Nak is on a distinguished road
You gotta be methodical. One step at a time. First step you've done. Since it runs when you pour fuel or starter fluid down the carb, it's a fuel problem. Next step: Do you hear the fuel pump run for 2 seconds when you turn on the ignition? If so, you've verified the wiring and the fuel pump relay. Still won't run? Verify you're getting fuel. Low tech: just stick your finger under the injector (If it's a TBI unit) when trying to start. Does your finger get wet? If so, you're getting fuel. At this point you might check your gas and see if it's good. you might have water in your fuel. Hi Tech: check your fuel pressure. if it's good you either have a problem with an injector or wiring. Also, check for bad gas.
Best: Get a real service manual, not a haines or chilton. Follow the diagnostic steps for your problem.
m3dragon
Feb 24, 2015 10:04 AM
jbobon007
14
Jul 1, 2011 05:30 PM
cle_chris1
Mar 12, 2008 07:45 PM
97blz4x4
Oct 14, 2007 07:45 PM
justblazin
Nov 19, 2006 12:10 AM
