Speedometer bounces
Old 04-22-2012, 10:53 AM
TSewell's Avatar
TSewell is on a distinguished road
Default Speedometer bounces
Hello. When i purchased my truck the speedometer was not working. So this morning i went out there to figure out why. Well I took the cable out and the cable looked fine. I noticed there was a adapter on the t-case. I took the adapter off and screwed the cable into t-case. Started it up and went driving. BINGO it works, sort of. The needle bounces as it moves up. Is my guage shot?
Old 04-23-2012, 11:33 PM
THePaRaSiTE5771's Avatar
THePaRaSiTE5771 is on a distinguished road
How does the inside of the speedometer cable look? Chewed up at all?
Old 04-24-2012, 03:10 AM
duxtoyz's Avatar
duxtoyz is on a distinguished road
my speedo on my blazer does the same thing. i sprayed sum lube down the inside of the cable housing and it helped a lil but it would take so much wd to make it work perfect i just said screw it and i drive by tach now, lol. ur cable is probably sticky and gummed up with years of crap getting in there. id replace the cable, they arent expensive.
Old 04-25-2012, 07:25 AM
TSewell's Avatar
When i pulled the cable out it did feel very tacky and gummed up. I think im going to use some break cleaner to clean it up and then put on some lithium grease or liquid graphite. Thanks guys.
insanefirewall
12-07-2014 07:20 PM
Frog
04-30-2012 11:16 AM
kenanddeb
06-29-2011 09:08 AM
janddcunningham
05-25-2011 11:14 AM
mkemu80
10-02-2009 12:10 PM
Quick Reply: Speedometer bounces
