01' Blazer spare tire question.
Old May 5, 2015 | 10:31 PM
Redtortoise38's Avatar
Redtortoise38 is on a distinguished road
Question 01' Blazer spare tire question.
I just bought a 2001 4 door Blazer LS (2wd). So, I have to replace my fuel pump and have to drop the tank. Before doing this I need to take out my spare tire underneath the truck. I started to do this the other day, and noticed that it takes a speacial "Small key" to get the spare all the way off. Is this something that I'm gonna have to call a dealership about, or what other options do I have? Thanks
Old May 6, 2015 | 03:42 PM
El_Beautor's Avatar
Special small key? As far as I know it only requires the lug wrench to lower it, then once it's on the ground you can turn the hook sideways and remove the cable from the wheel. I've never heard of a key being required with the underbody carrier. That being said there are many things that I've never encountered. Could you post a picture of the piece that requires the key?
Old May 6, 2015 | 04:44 PM
As soon as I figure out how to get a pic on here without using a URL. Thanks.
Old May 6, 2015 | 11:12 PM
Old May 7, 2015 | 02:21 PM
richphotos's Avatar
Try your door keys.. or your ignition key.
Old May 7, 2015 | 05:08 PM
The ignition cylinder has been replaced. Can't get ahold of the original owner(s).
Old May 7, 2015 | 09:13 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
Ignition key won't unlock that. You are correct, needs a little key. In leiu of using little key, use big drill bit. Preferably with a corded electric drill, unless you have a few extra charged up batteries ready to go for your cordless...
My $0.02
Old May 8, 2015 | 10:43 PM
jmparker82's Avatar
jmparker82 is on a distinguished road
That's after market. If you can't find a key in the blazer then grab a grinder or something and tear it apart or cut it off.
bdennis1983
Tires and Wheels
Jun 1, 2011 10:48 PM
tibby
May 23, 2011 05:33 PM
odfareal
Oct 19, 2009 02:47 AM
demon5spd
Jul 6, 2009 06:39 PM
bammontana
Tires and Wheels
Mar 2, 2009 12:52 PM
