01 Blazer starts when it wants
Old Mar 31, 2014 | 09:28 PM
Tbone64's Avatar
Tbone64 is on a distinguished road
Default 01 Blazer starts when it wants
Fuel pump and filter one year new, new plugs,injection system good and just replaced starter.
Might start on one turn 4/5 days and on day 6 nuthing, trys to turn over but won't. Wait a day or two and starts right up. There is no set pattern. when it turns over, runs fine?
Old Mar 31, 2014 | 09:56 PM
dragoon1101's Avatar
dragoon1101 is on a distinguished road
check your battery cables they tend to go bad i would just replace them all i believe there are three in total ( the BIG 3 http://www.s10forum.com/forum/f202/b...how-to-321330/ ) that is where i would start i would also check the wires on your starter could be loose.
Old Mar 31, 2014 | 11:58 PM
cleburne red's Avatar
If it cranks, even though it won't start and run, I wouldn't think the battery cables would be at fault.
What brand pump, etc? Probably ought to do a fuel pressure/leak down test, even if to only rule out fuel related problems.
Old Apr 1, 2014 | 01:15 AM
Tbone64's Avatar
did pressure/leak test- pump is good-- starter tight, battery cables good- sounds "fine" when it turns- also just stuck a new alternator in back in December,started right up today- work and back- but come morning might decide to take a day or two to start?
Old Apr 1, 2014 | 06:51 AM
richphotos's Avatar
When people say they did a pressure/leak down test, they never post the results.
What were the results for the pressure/leak down test? How was the test performed?
Old Apr 6, 2014 | 02:34 AM
Tbone64's Avatar
64 psi
Old Apr 6, 2014 | 02:08 PM
richphotos's Avatar
what was the leakdown?
epilou
Mar 8, 2013 03:30 PM
chris015
Sep 20, 2012 02:08 PM
FsTFwRd
Oct 9, 2011 06:27 PM
johnroe2727
Oct 8, 2010 09:45 AM
johnroe2727
Sep 14, 2010 11:36 PM
