1995 bumper vs 2000 bumper
Old Apr 12, 2025 | 11:20 AM
braden737's Avatar
Default 1995 bumper vs 2000 bumper
My rear bumper on my 2000 blazer is rotting out from the inside so id like to replace it. (Not the bumper ends, the actual bumper). I have looked and the 1995 version bumper is actually cheaper, would this version fit on my 2000?
Old Apr 14, 2025 | 10:22 AM
El_Beautor's Avatar
I'm not sure if the mounting plates that go from the frame to the bumper are the same. I kind of think they are different.
Another less expensive option to replace your bumper might be to try and find a decent condition used one from a U-pull type place if you have one nearby.
Old Apr 14, 2025 | 07:05 PM
braden737's Avatar
Maybe if they arent too different I could weld a bracket for it, but Ill definitely look at some junkyards around here. My only problem is I live in Iowa so lots of the junkers have rust, so it would be pointless for me to replace this bumper just for one that has rust eating at the backside of it. I could just buy the correct generation bumper but those are an extra 75-100 dollars. But i’ll definitely do some more research then if the mounts may be different,
Thanks El Beautor
Old Apr 15, 2025 | 09:33 AM
El_Beautor's Avatar
You're right that you likely could modify the mounting brackets if necessary. If you know how to weld, then almost anything is possible with some work.
As long as you're able to return it, you could even get the cheaper bumper to mock it up, and determine what changes may need to be made, and then if you decide it won't work you could return it for a refund or exchange it for the one that is designed for your truck.
You could also look at finding the matching mounting brackets for the bumper, although I'm not 100% sure that the frame is exactly the same between those years.
Old Apr 30, 2025 | 07:17 AM
blaziblaza's Avatar
blaziblaza can only hope to improve
I have already had a Blazer of this generation, and personally I think that the 1995-1997 bumpers are slightly different on the fastening side compared to the 1998-2000. You could maybe mount it with a little adjustment, but it won't be plug and play. It is especially necessary to check the supports and the spacing of the bolts. If you're comfortable with a little tinkering, it's doable. Otherwise, it can quickly become a hassle. Keep us posted if you get started!
Amykess
Sep 14, 2016 02:55 PM
jbw23
Feb 26, 2012 09:33 PM
blazerboy124
Nov 6, 2008 10:47 PM
Tomblazer
Nov 20, 2007 12:46 PM
speeddemon560
Jan 28, 2007 10:22 PM
