1997 chevy blazr lt Coolant leak from back of engine
Old Apr 1, 2021 | 06:32 PM
Johnny1025's Avatar
Johnny1025 is on a distinguished road
Default 1997 chevy blazr lt Coolant leak from back of engine
I replaced my front u joint and in order to remove it, i jacked up the tail of the drivetrain to slide the driveshaft out. I started the truck and now its leaking from the back of the engine. Would shifting the drivetrain up crack the block? Or did i disturb the intake manifold...?
Old Apr 1, 2021 | 09:44 PM
Any chance it's leaking from one of the heater hoses at the firewall?
Old Apr 2, 2021 | 09:00 AM
Johnny1025's Avatar
Not sure, ran out of daylight and steam last night. Where would the location be where they run through the firewall?
Old Apr 2, 2021 | 09:08 AM
I don't remember exactly what it looks like and I don't have mine with me to look at, but it will be to the right of center. You should be able to follow the hoses.
Old Apr 2, 2021 | 11:41 AM
Johnny1025's Avatar
It is either pooling or leaking here. Not sure what this hose is but its in the front of the engine and there is a visible trail to the back of the engine...does this engine tilt forqards or backwards? Im hoping backwards, because that would hopefully mean this fitting is leaking.
Old Apr 2, 2021 | 11:42 AM
Johnny1025's Avatar
Old Apr 2, 2021 | 11:48 AM
That large metal tube going off to the right is your thermostat housing (on the intake manifold end) and goes to your upper radiator hose. There's a rubber gasket on the thermostat that seals it, and it's not uncommon to have a leak there. I would drain the coolant, flush if necessary, then replace the thermostat with a new gasket. Also check the housing for rust or corrosion that would prevent a proper seal.
And the engine is supposed to tilt toward the back slightly, so leaks at the front could easily run off the back.
Old Apr 2, 2021 | 11:58 AM
Johnny1025's Avatar
Gotcha and its actually pooling up right under neath the fitting screwed in to the manifold, i think its the uppper, on my picture. One of the pictures you can see numbers on the hose. Thats where the pool is, like directly underneath it in a little gully in the casting.
Old Apr 2, 2021 | 12:02 PM
Johnny1025's Avatar
more pics, you can see the floresant dexcool.
Old Apr 2, 2021 | 12:07 PM
That hose with the numbers looks like EGR, not a coolant hose. It shouldn't be leaking from there, but it could still puddle there.
