2000 Blazer LS. 247k miles
Old Sep 12, 2020 | 10:07 PM
Micheler's Avatar
Micheler is on a distinguished road
Default 2000 Blazer LS. 247k miles
Oil gauge bouncing from 0 to 40. Oil changed 10 days ago. Put 2 quarts in today. Stick shows safe level. ???? Help!
Old Sep 13, 2020 | 07:19 PM
Why did you have to put two quarts in it today if the oil was just changed ten days ago? Was it already low? Is it leaking?
The oil pressure problem sounds like it could be a bad sending unit (behind the distributor), but you may have other problems if you're using a ton of oil.
Old Sep 13, 2020 | 08:52 PM
Micheler's Avatar
Default 2000 Blazer LS 247K
Tom,
Brought it to Firestone for the oil change 10 days ago when the gauge began bouncing from 0 to over 40. After that it was fine for 5 days or so...brought it back there yesterday and they told me there's a leak and added 1 at. I added another at as well. The gauge stayed at below 20 all day yesterday.Today it's fine . Drove highway miles and the gauge is at a little less than 40. Engine sounds fine. Think it's a sending unit?
Old Sep 13, 2020 | 09:06 PM
Sounds like the sending unit to me. That's also a common place for it to leak, but you would notice if it were leaking THAT much.
Old Sep 14, 2020 | 02:29 AM
Micheler's Avatar
Ok, will get the sending unit checked out....thank you!
Hopefully, that's not too much to repair!
Old Sep 14, 2020 | 04:05 AM
It's not too expensive. Hopefully that's all you need.
Old Sep 26, 2020 | 05:19 AM
go chevy's Avatar
I agree... You would think you would see oil somewhere, on the ground while parked, somewhere on the motor or the hood... Very strange indeed...
Tbone64
Jan 11, 2016 02:41 PM
dano440
40
Apr 22, 2012 11:34 AM
meesatiger73
Aug 5, 2011 07:12 PM
turtle51290
May 22, 2011 11:05 PM
dacop
16
Feb 8, 2009 09:17 PM
