2000 blazer runs like it has governors
Old May 4, 2010 | 11:49 PM
heartthrob427's Avatar
heartthrob427 is on a distinguished road
Angry 2000 blazer runs like it has governors
I HAVE A 2000 BLAZER WITH V6 AUTO , RUNS GOOD AS LONG AS YOU KEEP IT UNDER 2500 RPMS , WHEN YOU REV UP SETTING STILL IN PARK OR DRIVING DOWN THE ROAD [pedal to the metal] IT RUNS LIKE IT HAS GOVERNORS ON IT [ revs up and down ] IT HAS A NEW FUEL PUMP , FUEL FILTER , PLUGS , DIST. CAP, ROTOR AND THE COMPUTER HAS BEEN CHANGED [ might need reflashing ]. NO CODES IN THE COMPUTER . FUEL PRESSURE IS 45 PSI. thanks for any help , JIM
Old May 5, 2010 | 06:50 AM
First, lets turn that CAPS button off... It is not proper forum etiquette.
Now, 45psi from your fuel pump is no where near enough pressure. I am surprised that it is running. Check out the fuel system diagnostic link found in my signature.
rriddle3's Avatar
Originally Posted by heartthrob427
...FUEL PRESSURE IS 45 PSI...
I would look into that. Read this post:
96+ Fuel System Diagnosis
Old May 5, 2010 | 03:32 PM
Default 2000 blazer runs like it has governors
Hi again , the fuel pump is a walbo and is suppose to pump 100 psi , the fuel regulator must be bad . Right ? Thanks jim
Old May 5, 2010 | 04:50 PM
Only way to tell is by checking the pressure at the filter.
Old May 7, 2010 | 09:40 AM
HI AGAIN , THIS BLAZER WAS IDLING LAST NIGHT AND IT SHUT OFF ON ITS OWN AND WILL NOT HIT A LICK NOW , TURNS OVER OK BUT WILL NOT START . MY SNAP ON SCANNER SHOWS NO CODES IN THE COMPUTER . FUEL PUMP STILL RUNNING AND THE FUEL PRESSURE IS 52 PSI . [ i was wrong about the pressure being 45 psi ] HOW ABOUT THE USED COMPUTER NEEDING REFLASHING ? THANKS JIM
Old May 7, 2010 | 09:47 AM
Xanth's Avatar
Xanth is on a distinguished road
Holy Caps lock Batman....
Starter Possibly? Had a problem like this with my 65 Barracuda, replaced the starter and ignition and was good to go.
Old May 7, 2010 | 10:09 AM
rriddle3's Avatar
98+ No-Start - Engine Cranks OK - Ignition System Diagnosis
and please, once again, TURN OFF THE CAPS LOCK.
Old May 7, 2010 | 04:25 PM
hi again , the blazer started right up this morning , runs fine up to 3,000 rpms in park , then when you pull it in gear and try to accelerate it cuts off right then , i got it to rev up to 4,000 rpms one time in park . if you do this enough times it will not hit a lick until it cools off . i am going to check the coil and the coil driver next . thanks for the check sheet . no one has answered my question about the reflashing of the used computer, i did the 30 min. relearn of the security system. any one else has any answers let me know. thanks jim
Old May 7, 2010 | 07:32 PM
rriddle3's Avatar
Why did you replce the PCM and did it come from a Blazer of the same year with the same equipment and options as your's? If not, then a dealer reflash might be a good idea.
