2000 Chevy blazer rear wiper motor problem
Old Oct 29, 2010 | 09:38 AM
zaphfd74's Avatar
zaphfd74 is on a distinguished road
Default 2000 Chevy blazer rear wiper motor problem
When i turn on my rear wiper motor the arm only comes up part way and then makes a vibrating sound. Seems like the arm is tight on the shaft. If i push it up with my hand it works, but as soon as I shut it off and turn it on it gets stuck again. Any ideas.
Thanks
Old Oct 29, 2010 | 01:56 PM
97chevyblaze's Avatar
97chevyblaze is on a distinguished road
lol i got the same problem on my 97
Old Oct 29, 2010 | 02:58 PM
zaphfd74's Avatar
I checked it out a little farther. Even though the arm is tight on the shaft I removed it and turned on the motor and it worked fine. Turns out the point where they attach together is stripped. Going to try a new wiper arm and I am hoping that works and I didn't let the motor shaft get stripped. Hope that this helps
Old Oct 29, 2010 | 04:13 PM
Remove the rear wiper arm. Clean out the splines on the shaft from the motor with a pick. Reinstall. This worked on my old '00 Bravada.
Old Oct 30, 2010 | 12:10 PM
zaphfd74's Avatar
Took the arm off and cleaned it but still not working. I am going to replace the wiper arm and see what happens. If this does not work I guess the arm on the motor is stripped?
Old Nov 1, 2010 | 05:40 PM
TriBlaKer's Avatar
TriBlaKer is on a distinguished road
i have the same prob with my 98, the motor seems to be working cause it makes a loud clicking noise but no movement on the outside.
Old Nov 1, 2010 | 08:08 PM
zaphfd74's Avatar
I replaced the arm today and it still did not work. I assumed the shaft on the motor was stripped so got a new motor and all worked well. Just to make sure take the arm off and make sure the shaft turns as is supposed to. If it does start with the arm and do what i did.
Old Nov 30, 2010 | 05:30 PM
cue755's Avatar
cue755 is on a distinguished road
how do you remove rear wiper arm on blazer
Old Dec 1, 2010 | 08:26 AM
chevytruckdood's Avatar
just antoehr thing on my list of todos......
Old Dec 1, 2010 | 11:36 AM
Flip up the little black plastic cover and remove the nut.
litterbox99
Sep 22, 2014 05:39 PM
jrb_fishy
Dec 23, 2013 06:15 PM
panicman57
Jan 10, 2011 08:07 PM
pusher_sr
Mar 6, 2005 04:26 AM
