2001 Blazer service engine soon and service 4wd drive soon.
Old Jul 23, 2019 | 08:23 PM
Ltrentdewit's Avatar
Ltrentdewit is on a distinguished road
Default 2001 Blazer service engine soon and service 4wd drive soon.
These two lights continue to light up on my car. This blazer lt is old and I want to get it into running condition but these lights will not go off. I ordered a new part to replace the 4 wd module. I have replaced the oxygen sensors and the MAF, replaced shift silicons. Car runs great.
codes that pop up:
c0237
c0281
p0101
p0131
p0151
help is needed. I just wan these lights to go off.
p0756
Old Jul 24, 2019 | 05:13 PM
codes that pop up:
c0237
c0281
p0101
p0131
p0151
p0756
You should be able to look up the meaning of the codes. What year and what type of 4wd? (3-button or 4-button?) What are the symptoms?
Old Jul 24, 2019 | 05:28 PM
Default If found the meaning of codes
2001 blazer
C0237 rear spreed sensor or EBCM system
C0281 stop lamp switch
P0101 mass air flow sensor (changed)
P0131 HO 25 circuit low variance bank 1
P0151 02 sensor drivers side (changed)
P0756 shift selinoid B performance/ stuck/ off (changed)
4 button panel.
Old Jul 24, 2019 | 06:35 PM
2001ZR2's Avatar
I would be worried about the p0756 as I would get that one before my transmission went out. Do you have hard shifts? I think mine was 1-2 or 2-3. I also lost transmission fluid.due to a line popping off on the highway.
Look up the code but i think it's something that can be fixed by replacing a valve or solenoid in the valve body.
I think the P0131 refers to the O2 sensor on the drivers side but some research is needed.
I would run down the mass air flow sensor code and see if it clears the p0131,p0151
Old Jul 24, 2019 | 08:51 PM
Changed MAF and all O2 sensors. I also changed out the 4wd module. Only light left on is the check engine light now.
any suggestions?
bmk10
Jan 12, 2019 10:39 PM
BLAZINFORSURE
Nov 10, 2017 08:58 AM
Jimmysls98
Mar 15, 2008 05:59 PM
Mule
Apr 9, 2007 03:21 PM
andyjwood
Oct 29, 2006 02:51 PM
