o2 Sensor?
Old Feb 6, 2008 | 08:45 PM
Jimmysls98's Avatar
Jimmysls98 is an unknown quantity at this point
Default o2 Sensor?
ok i have rough idle, problem picking up speed and and engine code p0100 not sureone hundred and what is it o2 Sensor?
Old Feb 7, 2008 | 01:40 AM
Chevy Lover's Avatar
Default RE: o2 Sensor?
I can't help you there. My list of codes starts at P0101 and my O2 sensor codes start at P0131.
Old Mar 15, 2008 | 01:02 PM
tabluvsyou's Avatar
tabluvsyou is an unknown quantity at this point
i am having the same problem with my 95 blazer and my bf changed my 02 sensor and it is still doing it. i took it to the shop yesterday and they told me it was my efg valve. so just a thought
Old Mar 15, 2008 | 02:21 PM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
P0100 - MAF Sensor Circuit Insufficient Activity
Old Mar 15, 2008 | 05:59 PM
As xmradioguy said, its a MAF sensor code. I would recommend cleaning the MAF sensor and seeing how it does then. Before you do that, just unplug the MAF and see if the rough idle clears up. If it does, then the MAF is the problem. Clean it and see how things go. Just be careful when cleaning the small elements on the sensor.
Now, while the rough idle may be a similar problem to what you are experiencing, tabluvsyou, your truck will never display this code. That is due to the fact that the CPI motors do not use a MAF sensor.
joey
Aug 27, 2012 06:33 PM
GM hater
Jan 9, 2010 02:32 PM
theeviltwinn
Oct 23, 2009 06:37 AM
daniel010
Feb 2, 2009 06:50 AM
Spartan66
Jul 11, 2008 02:34 PM
