2001 blazer/trailblazer
Old Mar 19, 2019 | 06:52 PM
Mikk's Avatar
Mikk is on a distinguished road
Default 2001 blazer/trailblazer
Just installed new motor...went to start and is starting in on position....could it be a bad ground....changed ignition switch already....could bad positive battery cables be at fault if they r corroded inside the caseing??
Old Mar 19, 2019 | 07:20 PM
Trukntigger's Avatar
I’ll state the obvious but not sure on cure. You state replaced motor. Was not doing this before this change I assume so you must have something plugged in wrong under the hood most likely thing that happened. Your going to need the wiring layout for starting circuit and debug from that.
Old Mar 20, 2019 | 06:33 AM
rriddle3's Avatar
This question has already been asked in this post:
Ignition Switch Problem
Double posting is against forum rules.
*Thread Closed*
blazerb
May 23, 2015 04:06 PM
shotnva777
Nov 9, 2011 06:40 AM
Unlimitedsp
Oct 13, 2011 09:20 AM
GregM
Aug 15, 2010 05:12 AM
Chevy67
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Aug 28, 2009 08:23 AM
