2004 4 wheel drive problems
Old Aug 13, 2013 | 10:32 PM
kzooblazer's Avatar
kzooblazer is on a distinguished road
Default 2004 4 wheel drive problems
i have a 04 blazer and it will shift into 4 hi and 4 lo with no problem but when i put any power into it i hear this loud ratcheting sound. it sounds like it is coming from the front drivers side. if any one could point me in the right direction it would really help.
Old Aug 14, 2013 | 12:59 AM
95BlackGA's Avatar
95BlackGA is an unknown quantity at this point
Sounds like the transfer case isn't fully locking in. Could be a weak vacuum to the actuator. A vacuum leak or a blown out diaphragm in the actuator could cause this. Pull the battery and battery tray, the actuator will be located right below the tray. Have someone engage the 4 wheel drive, and see if the cable has good movement.
Old Aug 14, 2013 | 11:26 AM
kzooblazer's Avatar
thank you, i was thinking the same thing. thanks again
Old Aug 18, 2013 | 07:56 PM
sillyak's Avatar
sillyak is on a distinguished road
Check the u-joint and CV joint on the drive shaft. I had a weird loud clanking sound and found out the boot on the driveshaft was torn and the CV joint was toast.
mirrorimij
Jun 8, 2019 03:34 PM
MTopper
Jul 12, 2011 12:19 AM
lizzj70
Jun 23, 2010 06:57 PM
kodieg
Feb 23, 2010 03:48 PM
Quicksilver
Oct 15, 2008 06:41 AM
