2005 blazer 4wd 2 door 188000km check engine light flashing rpms go up and down
I have a 2005 blazer 4wd 2 door 188000km check engine light flashing when I go on the hwy. The rpms go up and down when i come to a stop occasionally in the city. I have no codes coming up at all. It runs a little rough and sucks gas. I get 250km from a full tank. Thanks in advance to anyone with any ideas .I've replaced the following parts .
Plugs
Cap
Rotor
Wires
Distributor
Ignition module
Ignition coil
IAC
MAF
MAP
EGR
Spider
Fuel Filter
Fuel pump
Crack sensor
All oxygen sensors
throttle position sensor
Plugs
Cap
Rotor
Wires
Distributor
Ignition module
Ignition coil
IAC
MAF
MAP
EGR
Spider
Fuel Filter
Fuel pump
Crack sensor
All oxygen sensors
Plugs
Cap
Rotor
Wires
Distributor
Ignition module
Ignition coil
IAC
MAF
MAP
EGR
Spider
Fuel Filter
Fuel pump
Crack sensor
All oxygen sensors
Plugs
Cap
Rotor
Wires
Distributor
Ignition module
Ignition coil
IAC
MAF
MAP
EGR
Spider
Fuel Filter
Fuel pump
Crack sensor
All oxygen sensors
dont remember these things having a "Crack sensor", you live in detroit?
Sounds like a vacuum leak, pull the vacuum hoses off the upper intake and cap the ports on the manifold, do not unhook the PCV or Brake booster. and take it for a test run, note you will loose 4WD and HVAC direction controls with the hoses disconnected.
Hey neighbor! I was born and raised in Scarborough, Morningside and Sheppard. Live outside of milton now
Atleast you know you got a bunch of good parts on it now lol... thats the way I look at getting parts that aren't needed...
Did you keep the old as spares or to check if they were still good? Sometimes new is worst then original lol
RonToBlaze
07-06-2009 07:52 PM
Inferno
06-11-2008 05:06 AM
