33's are SWEEET!!!!
gocartone: Not really any different, if anything its more stable now because my center of gravity is lowered being as the tires are spaced out and they are a wider pattern.
sendero: 2 inch body lift will clear 31's just fine. For 33's you need the body lift, some shackles or add-a-leafs, and a torsion bar crank up. All of that followed by a little fender trimming and an alignment (need to take mine in again, something is up with the camber on the driver side).
jimmyboy: Thanks, much appreciated.
ORIGINAL: a_tack
What did you do with your 31's??? you should totally give them to me..hahaha
