400 sbc vs 350
ORIGINAL: tx_marez_tx
bi-weekly fill-ups here i come!
eh. right now im open for options. im more or less leaning towards a 350 anyways because i already know it'll fit in a 1st gen blazer without any major problems to take care of.
SBC 400's were the first attempt at smog reduction back in the day. Those blocks suffered a lot of problems. A few builders did manage to get HP back into them. The Chevy 400 will be more costly to rebuild. I'd go for the 350.
ORIGINAL: xmradioguy
Just FYI the 400 and 350 blocks are the same physical size
ORIGINAL: WolfPack
Yea...but you'll be driving a Prius...
i catch hell about that from the guys every time i mention toyota now
ORIGINAL: swartlkk
Depending on your location, yanking the computer, etc may cause you to fail your inspections.
If it were me, I would go with the 350 and build it up. You can easily get 350-400HP out of a 350 on a budget build.
CA is the worst of the worst in terms of making changes like this. All I can say is good luck.
383 Stroker !
![](https://i15.photobucket.com/albums/a360/ZEDR2/6CarShow.jpg)
ORIGINAL: swartlkk
ORIGINAL: if6was9
It all started in CA back in '67. AIR systems were required for cars with automatic trans. CA has had the strictest tail pipe emissions since.
ORIGINAL: swartlkk
I'll eventually figure it out. I poked around the Vehicle Code last night, and the DMV website. In theory, according to the Air Resource Board (or whomever), you can do it, but it has to be as clean or cleaner than the current engine. Any time you swap an engine, you are required to report it to DMV so they can issue a new ID number for your vehicle and re-register you. The fee appears to be $2.00 by statute. After all this, you have to take it to a DMV "referee" who will inspect the vehicle and presumably smog it.
Although licensing the first time round would be a hassle, I suppose it ultimately comes down to whether a newer 350 can run cleaner than a 10+ year old 4.3L. I have no idea. I assume the smallblock would be a bit more thirsty though.
