400 sbc vs 350
Old Mar 15, 2008 | 07:29 PM
WolfPack's Avatar
Default RE: 400 sbc vs 350
ORIGINAL: tx_marez_tx
bi-weekly fill-ups here i come!
Yea...but you'll be driving a Prius...
Old Mar 15, 2008 | 07:38 PM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
eh. right now im open for options. im more or less leaning towards a 350 anyways because i already know it'll fit in a 1st gen blazer without any major problems to take care of.
Just FYI the 400 and 350 blocks are the same physical size
Old Mar 16, 2008 | 01:29 AM
if6was9's Avatar
if6was9 is an unknown quantity at this point
SBC 400's were the first attempt at smog reduction back in the day. Those blocks suffered a lot of problems. A few builders did manage to get HP back into them. The Chevy 400 will be more costly to rebuild. I'd go for the 350.
Old Mar 16, 2008 | 01:46 AM
tx_marez_tx's Avatar
tx_marez_tx is an unknown quantity at this point
ORIGINAL: xmradioguy
ya i knew that. i've just never worked on one. my biggest issue was wondering how different the intake and heads were, like the ability to work on them easily in comparison to a 350. then accessory brackets, how different is the set up and what not. will the water pump protrude too far out to use a clutch style fan. simple stuff that you wouldnt think would be a problem outside the box, then once you get inside the box it becomes a major issue.
ORIGINAL: WolfPack
lol ya ya i know. dont remind me :P
i catch hell about that from the guys every time i mention toyota now
Old Mar 16, 2008 | 03:04 AM
uberfiend's Avatar
uberfiend is an unknown quantity at this point
ORIGINAL: swartlkk
Depending on your location, yanking the computer, etc may cause you to fail your inspections.
If it were me, I would go with the 350 and build it up. You can easily get 350-400HP out of a 350 on a budget build.
Is it possible to get a conversion like this licensed in any state? I live in CA where I expect DMV would not be too enthusiastic...
Old Mar 16, 2008 | 09:00 AM
CA is the worst of the worst in terms of making changes like this. All I can say is good luck.
Old Mar 16, 2008 | 12:54 PM
Zed's Avatar
Zed
Zed is an unknown quantity at this point
383 Stroker !
Old Mar 16, 2008 | 01:56 PM
if6was9's Avatar
ORIGINAL: swartlkk
It all started in CA back in '67. AIR systems were required for cars with automatic trans. CA has had the strictest tail pipe emissions since.
Old Mar 16, 2008 | 09:22 PM
ORIGINAL: if6was9
ORIGINAL: swartlkk
ha, ya theres about 3 things keeping me from moving back to CA once i can afford the move to anywhere. emissions requirements (granted with a daily driver getting 45+ it wont effect that), property taxes, and cost of living in general. i would just as soon be happier moving back to TX.
Old Mar 17, 2008 | 03:00 AM
uberfiend's Avatar
I'll eventually figure it out. I poked around the Vehicle Code last night, and the DMV website. In theory, according to the Air Resource Board (or whomever), you can do it, but it has to be as clean or cleaner than the current engine. Any time you swap an engine, you are required to report it to DMV so they can issue a new ID number for your vehicle and re-register you. The fee appears to be $2.00 by statute. After all this, you have to take it to a DMV "referee" who will inspect the vehicle and presumably smog it.
Although licensing the first time round would be a hassle, I suppose it ultimately comes down to whether a newer 350 can run cleaner than a 10+ year old 4.3L. I have no idea. I assume the smallblock would be a bit more thirsty though.
