4400lbs
Old Feb 9, 2008 | 06:00 PM
drperry's Avatar
Default 4400lbs
And according to the specs it should weigh in at like 3866lbs.
My truck needs a diet, I think
4400 - 180 = 4220lbs without me in it...
4220 - 152 = 4068lbs w/o 30" tires
4068 + 132 = 4200lbs with factory tires
4200 - 50 = 4150lbs without the sub, amps and small tool box.
4150 - 20 = 4130lbs without the extra lights (being VERY generous to the weight of all the lights, lol)
4130 - 3866 = 264lbs
I really doubt the brushguard weighs 264lbs
Old Feb 9, 2008 | 06:04 PM
blazin97's Avatar
blazin97 is on a distinguished road
Default RE: 4400lbs
Unless you have a very small box/sub combo I doubt it only ways 50 lbs my 2 12's in sealed box with amp weighs in at 100 lps plus then you got your tool box
Old Feb 9, 2008 | 06:23 PM
drperry's Avatar
Default RE: 4400lbs
It's a single Alpine 10" sub... and I can lift the whole shebang with one hand.... It ain't that heavy, I'm not exactly in the best of shape
Old Feb 9, 2008 | 06:54 PM
thegr81's Avatar
Default RE: 4400lbs
Your truck is a tank, LOL!!
Old Feb 9, 2008 | 07:04 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: 4400lbs
could have some excess mud stuck inside the frame rails and other places??
Old Feb 9, 2008 | 07:06 PM
Zasder's Avatar
Zasder is an unknown quantity at this point
Default RE: 4400lbs
Edit:
Nevermind I miss read....the specs sheets...
How did you weigh it anyways?
Old Feb 9, 2008 | 07:10 PM
thegr81's Avatar
Default RE: 4400lbs
ORIGINAL: Zasder
Edit:
Thats what I was thinking the starting weight number of 3866 came from if you add all the 4x4 equipment it adds up faster!!
Old Feb 9, 2008 | 08:02 PM
drperry's Avatar
Default RE: 4400lbs
I used a weigh scale... and that 3866lbs is the 4x4 curb weight
Taken right from the specs:
Curb weight (lb / kg):
2WD: 3591 / 1629
4WD: 3866 / 1754
Old Feb 9, 2008 | 08:13 PM
mdehoogh's Avatar
Default RE: 4400lbs
would the 5spd trans weigh more than the 4spd?
also, does the stock weight include gas? and did you weigh yours soon after fill-up?
Old Feb 9, 2008 | 08:34 PM
drperry's Avatar
Default RE: 4400lbs
5 speed should be lighter... It's smaller, and doesn't have the tubing for trans cooling...and that was with 1/2 tank of gas...
Unless the iron front diff is THAT much heavier than the aluminum [sm=jawdrop.gif]
I forgot about that... But still I can't imagine it being more than 20lbs heavier... 50lbs at the most...
