4wd issues
Old Nov 19, 2020 | 06:37 PM
lukejrtompkins's Avatar
lukejrtompkins is on a distinguished road
Default 4wd issues
Hello, I have a 2000 GMC Sonoma (4.3 Vortec) and I’ve been trying to engage it in 4wd but when I’m in neutral and I click the 4hi, 4lo or even 2hi nothing happens, not even a flash, I’ve checked fuses and connections and nothing seems to look bad, fuses are fine, kinda stuck.
Old Nov 25, 2020 | 05:18 PM
rlwhitaker's Avatar
rlwhitaker is on a distinguished road
Default 4WD problem
Just had the same problem. I replaced the TCCM (transfer case control module).. Put in a Dorman brand. Solved that problem. Now having problem with the actuator. Replacing this weekend. TCCM controls the actuator depending on which button you select ie: 2hi-4hi-4lo-Auto 4WD. TCCM is under dash and actuator is underneath by transmission/transfer case. Hope this helps..
Alexzannder
Dec 21, 2020 09:54 AM
grannycar
Aug 19, 2012 07:46 PM
thehoff
Jan 9, 2010 11:15 AM
pike87
Feb 1, 2008 03:03 PM
zombiebebop
Engine & Internal
Dec 8, 2006 03:15 PM
