70 MPH?
Old Jan 2, 2009 | 09:06 AM
blznlowxtreme's Avatar
blznlowxtreme is an unknown quantity at this point
Default RE: 70 MPH?
ORIGINAL: rriddle3
D'oh!!!
And I can't even use New Year's hangover as an excuse.
yea you can. we wont tell
Old Jan 6, 2009 | 03:57 PM
c5ce's Avatar
c5ce is an unknown quantity at this point
Default RE: 70 MPH?
Using cell phones and following the wife in the car, using cruise, the results are
38 MPH in the Blazer = 35 MPH
77 MPH in the Blazer = 70 MPH
Is there a difference in between truck and car tires, even though they are P235/70R15s? In other words, are truck tires (ATs)taller than car tires of the same size? The Blazer has car tires on it. Its a 99 LT 4x4. The tires on the Blazer matches the door sticker and RPO code. The RPO code doesn't specify car or truck tire.
Old Jan 6, 2009 | 04:17 PM
Byte Stryke's Avatar
Byte Stryke is an unknown quantity at this point
Default RE: 70 MPH?
ORIGINAL: swartlkk
Assuming you are quoting the RPM with the transmission in 4th gear and the torque converter locked up... The 700R4/4L60/4L60E has an 4th gear (OD) ratio of 0.7:1. With 3.73 gears, that results in a final drive ratio of 2.61:1. So for every 2.61 revolutions of the motor, the wheel will turn 1 time. A 235/70R15 tire is a ~28" diameter tire which goes through 722 revolutions per mile. This results in a speed of 63.68MPH at 2000RPM. At 70MPH, the engine would be turning ~2200RPM.
MI/HR = ( REV/MIN * 60 MIN/HR ) divided by ( Tire REV/MI * Final Drive Ratio )
Final Drive Ratio = Transmission Gear Ratio * Axle Ratio
Tire REV/MI = 63630 IN/MI divided by IN/REV [which is circumference = PI * DIAMETER]
now if you were REALLY Smart....
What is the air speed velocity of an unladen swallow?
[8D]
Old Jan 6, 2009 | 04:44 PM
Default RE: 70 MPH?
ORIGINAL: c5ce
Is there a difference in between truck and car tires, even though they are P235/70R15s? In other words, are truck tires (ATs) taller than car tires of the same size? The Blazer has car tires on it. Its a 99 LT 4x4. The tires on the Blazer matches the door sticker and RPO code. The RPO code doesn't specify car or truck tire.
This would average out to be around a 9% difference in the speedometer if your measuring devices are accurate enough. Even if the vehicle were setup for 235/75R15 tires, that would only represent a ~3% difference to drop to 235/70R15. If someone had had the tire sized changed for 31" tires, then the difference dropping down to the 235/70R15 tires would be ~7%. ~10% for a correction factor to 32" tires and dropping back to 235/70R15
As far as the difference between a LT235/70R15 and a P235/70R15, no, ideally speaking, there is no difference as the number represent the width, aspect ratio, and the rim diameter. The difference is in the construction. An LT tire is generally much heavier in construction with more plies on both the tread and sidewall areas to handle higher loads. As a result, the LT tire may have a larger loaded diameter because one may be less likely to squat under load.
Old Jan 6, 2009 | 05:02 PM
c5ce's Avatar
Default RE: 70 MPH?
Thanks guys!!!!
Old Jan 9, 2009 | 03:15 PM
c5ce's Avatar
Default RE: 70 MPH?
Doesn't this also make the odometer incorrect such as make the odometer show more miles on the truck than what it really has??????
Old Jan 9, 2009 | 05:04 PM
Default RE: 70 MPH?
What are you talking about? Right now, if your speedometer is off, so is your odometer.
Old Jan 9, 2009 | 06:07 PM
c5ce's Avatar
Default RE: 70 MPH?
The point is, odo reflects more miles than what is actually on the truck. GM dealer service manual says replace the IP. I had forgotten about the speedo issue I had with an 04 Silverado Z71. IP was replaced and it fixed the issue.
Old Jan 9, 2009 | 10:44 PM
Default RE: 70 MPH?
You have two things at work here. Speedo is fast and ODO is climbing at a faster rate. Both of these could be caused by an improperly input tire diameter or gear ratio.
JAS69
Nov 20, 2009 09:12 AM
99 Blazer 4x4
Sep 6, 2007 05:06 PM
woodsballr
Apr 19, 2007 12:12 PM
joey
Feb 19, 2007 03:50 AM
syrblitz19
Jun 17, 2006 09:13 AM
