83 blazer rear differential HELP!!!!
Old Aug 24, 2010 | 07:06 PM
J-Dizzle's Avatar
J-Dizzle is on a distinguished road
Default 83 blazer rear differential HELP!!!!
need tourqe specs on the U brackets on the rear differential and the tourqe specs on then little bolt that holds the main pin in the diff
Old Aug 24, 2010 | 08:02 PM
Fullsize or s-series? Well.. I'm not sure if it matters. I believe the torque spec on the bearing cap bolts should be 55-60ftlbs. The spider cross pin should be around 20ftlbs or just good-n-tight..
Old Aug 25, 2010 | 12:47 AM
J-Dizzle's Avatar
Full size v8 305 i wana say ten bolt rear diff
Full size
also wat type of gear fluid should i use like wat weight
Last edited by swartlkk; Aug 25, 2010 at 06:17 PM. Reason: *Consecutive Posts* - Please use the edit feature to add more information to your post if another member has yet to reply.
Old Aug 25, 2010 | 06:19 PM
You can use pretty much whatever gear lube you want in the rear. 80w90 or 80w140 are both acceptable depending on your climate (heavier for hotter climates). You may experience lower mileage using 80w140 in cooler climates though.
Drew4711
Oct 6, 2012 12:47 PM
Twonpablo
Jun 28, 2011 05:24 PM
dart08
Oct 12, 2009 04:15 PM
audkay
Jul 29, 2009 03:41 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
