HELP rear differential questions
Old Jun 28, 2011 | 08:38 AM
Twonpablo's Avatar
Twonpablo is on a distinguished road
Default HELP rear differential questions
so....here is the deal k5 blazer 84 built motor 10 bolt rear 35s. pretty standard. well here is what happend.
there was a crappy flame sticker on the diff cover so i took it off when i bought it. about a week later noticed fluid coming out of a hole that the sticker was covering up. went out and bought a new cover and new syn fluid. all was fine. WHen i pulled the cover off the ring gear had a single broken tooth but that was it. it had begun to whine and was completely out of fluid btw.
after the process had no ill affects except if i kicked it while turning you can feel the ring gear not line up. its that jerky every 8 foot feeling. but beside that no biggie. now take a look at the pic. its like the cover is too small.
i know nothing about difs so any advice is much appreciated.
Old Jun 28, 2011 | 11:28 AM
One broken tooth is more than enough to allow the pinion to start eating the ring gear & vise verse. Those dents are likely caused by more teeth coming off and being tossed around inside the diff.
Old Jun 28, 2011 | 12:49 PM
Twonpablo's Avatar
thank you for the response. so new pinion and ring gear yeah? is that hard to put it? do i have to replace all the bearings and stuff? basically, if it was your vehicle what would you do next? Again thank you i really am kinda daunted so your help is invaluable
Old Jun 28, 2011 | 05:24 PM
You would need to replace all of the bearings. The difficult part isn't in putting those things in, it is in getting all of the clearances set properly. You can run a Google search for "how to install a ring & pinion" and you should get the gist of what's necessary. Some very specialized tooling is required to do it correctly.
If it were me, I would replace these components myself, but I've done it before and have some of the tools required and access to everything necessary after a phone call or two.
Drew4711
Oct 6, 2012 12:47 PM
J-Dizzle
Aug 25, 2010 06:19 PM
audkay
Jul 29, 2009 03:41 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
MusicMaverick
Apr 21, 2007 02:17 PM
