96 Chevy blazer S 10 rear wiper not working
When I press button windshield washer fluid comes out the rear wiper does not work is there a separate fuse for them to cut the motor be bad it’s not stuck try to junkyard motor out of a newer car he said the motor was good any ideas before I purchase a new one
yes. there are 2 pumps on the tank. rear one is higher than the front. when rear spray does not work, but front one does, check fluid level. it is a long hose from the front, there can be leaks. look for dripping onto the ground, if you can hear the pump motor running, but no spray. the nozzle can be plugged too.
rear wiper washer works the motor for the wiper arm does not did not see a separate fuse is there something I’m missing I noticed a lot of these models about the same year has the same problem any answers
litterbox99
Sep 22, 2014 05:39 PM
99blzr
Dec 18, 2011 06:47 PM
lionel2
Mar 24, 2011 08:29 AM
