96 Chevy blazer S 10 rear wiper not working
Old Dec 9, 2019 | 01:58 PM
Cervones's Avatar
Cervones is on a distinguished road
Default 96 Chevy blazer S 10 rear wiper not working
When I press button windshield washer fluid comes out the rear wiper does not work is there a separate fuse for them to cut the motor be bad it’s not stuck try to junkyard motor out of a newer car he said the motor was good any ideas before I purchase a new one
Old Dec 24, 2019 | 04:02 PM
sepress1's Avatar
sepress1 is on a distinguished road
be sure to use some good lubricant on the hinge of the wiper arm. (tri-flo). make sure the arm is free to flex at the hinge.
Old Dec 27, 2019 | 08:06 PM
bravo99's Avatar
sorry I haven't seen where else to put this question... where in the world is the reservoir for the rear washer spray on 4-door Jimmy Blazer Bravada? is it Plumbing from all the way up front?
Old Dec 27, 2019 | 08:46 PM
sepress1's Avatar
yes. there are 2 pumps on the tank. rear one is higher than the front. when rear spray does not work, but front one does, check fluid level. it is a long hose from the front, there can be leaks. look for dripping onto the ground, if you can hear the pump motor running, but no spray. the nozzle can be plugged too.
Old Dec 29, 2019 | 12:54 PM
Cervones's Avatar
Default Rear wiper motor not working on 96 Chevy blazer
rear wiper washer works the motor for the wiper arm does not did not see a separate fuse is there something I’m missing I noticed a lot of these models about the same year has the same problem any answers
Old Dec 29, 2019 | 01:35 PM
I know when my 99 rear wiper stopped working, I just grabbed one from the yard. Might want to double check the motor to see if it's good..
Old Dec 29, 2019 | 04:57 PM
bravo99's Avatar
thank you sepress.
jesses99blazer
Sep 6, 2018 11:18 AM
litterbox99
Sep 22, 2014 05:39 PM
99blzr
Dec 18, 2011 06:47 PM
lionel2
Mar 24, 2011 08:29 AM
Viciouss
Apr 28, 2006 09:57 AM
