97 2 door blazer driver window window switch
Old Mar 10, 2018 | 03:05 AM
Casey Draper's Avatar
Casey Draper is on a distinguished road
Default 97 2 door blazer driver window window switch
My driver side window switch when I wanna roll the window down I gotta push really hard to make it go down does anyone know why that is? And what if I wanna make a little more power to the engine say by putting a intake on it how would I go about doing that? Also the passenger side interior handle is becoming hard to open the door unless you pull the door in then pull the handle anyone else have the same problem?
Old Mar 10, 2018 | 04:46 AM
As for the switch there could be many reasons. Broken plastic, oxide on the contacts. Bad ground on the motor. Not sure but maybe somebody has solved the same problem before.
For performance mods you may start in the performance & brainstorming section.
Plus this is a good starting point.
https://blazerforum.com/forum/perfor...ng-mods-66993/
Old Mar 10, 2018 | 05:15 AM
Thanks for the response it kinda helped but I'm gonna have to look further into it and see what I can figure out
mamawolf70
Apr 10, 2020 10:44 AM
RSDEVIL
Feb 23, 2016 06:30 PM
punka088
Apr 18, 2015 02:43 AM
Ryan Johnson
Aug 14, 2014 10:18 PM
MikeTastic
Aug 8, 2012 04:41 PM
