Airbag lights on
Old Mar 14, 2018 | 09:14 AM
Johnny Colon Sr's Avatar
Johnny Colon Sr is on a distinguished road
Default Airbag lights on
well frost I was looking for the mudule for the air bag but where should I start the scanner only day infallible restraint mudule no po number check under the seat for yellow plug didn’t see any check center console near the back didn’t see any unless it’s under the rug no opening to access it the only think I didn’t wrong is. When I was changing the pitman arm I think the steering wheel spin around not sure any help I appreciate it thank
Old Mar 14, 2018 | 02:24 PM
The front modules are mounted on a cross member behind the bumper. They are box-shaped, about 3" across.
The one between the front seats is under the carpet. You have to cut the carpet with a utility knife to get at it.
It is worth unplugging the connectors and reconnecting them for each of the modules.
1999 SIR component locations.
File Type: pdf
Blazin88SS
Nov 27, 2012 08:41 PM
neemo6
May 4, 2012 09:36 PM
edavison
Dec 20, 2010 09:55 PM
hotrod28
Nov 4, 2006 08:11 PM
