97 seized
Old Aug 19, 2024 | 01:48 PM
KungpaoSeizedBlazer's Avatar
KungpaoSeizedBlazer is on a distinguished road
Default 97 seized
New here, just seeing if anyone had pearls of wisdom
97 Blazer sat for a good 5 years, hoping to soak the cylinders but I see now that the spark plugs are on the side behind the wheels, so not sure if that's the proper entry for soaking it? Is it even possible?
Thanks
Old Aug 22, 2024 | 10:25 AM
El_Beautor's Avatar
You should be able to access the spark plug holes from the wheel wells, especially if you remove tires and pop off the mud deflector flaps. On the driver side there is one spark plug that is partially blocked by the steering shaft (I think it's #5?), which can be a challenge, but there's a couple ways you can get around that. Some people use a stubby socket with a wobble extension, and others have temporarily disconnected the steering shaft.
For those of us who have done a body-lift on their trucks it changes the angles and increases the fender gap enough to make it easy to access all 6 spark plugs.
Benyetti
The Chop Shop
Oct 1, 2016 02:57 PM
4doorblazer
Aug 24, 2014 01:36 PM
Big Country
Aug 7, 2011 02:16 AM
bootlegger
Jul 23, 2010 01:12 PM
danyboy
Oct 21, 2009 05:43 AM
