98 blazer help with trouble codes
Old May 30, 2025 | 09:38 PM
Cbartee2's Avatar
Cbartee2 is on a distinguished road
Unhappy 98 blazer help with trouble codes
Im looking for help on my 98 blazer has the 4.3v6 4x4 it has a P0300 random misfire code and a P0405 code I have thrown so many parts at this thing and I still can't figure it out. I have just put a new EGR valve, replaced all 6 plugs, new distributor cap and rotor, and a bunch of other parts didn't make a difference. Please help!
Old May 31, 2025 | 12:52 PM
TheJimmyMan's Avatar
TheJimmyMan will become famous soon enough
Is the truck running fine though? Sometimes the CEL (check engine light) will just be on because these are some old vehicles.
Old May 31, 2025 | 12:54 PM
Cbartee2's Avatar
No it isn't at all it runs very bad it idles rough and when put in drives it stalls sometimes and if I try to drive it it takes roughly 15 seconds to reach 30 mph
Old May 31, 2025 | 06:18 PM
Have you checked the ignition coil and ignition control module?
Old May 31, 2025 | 06:20 PM
Cbartee2's Avatar
Yes actually. I am beginning to think the spider injection system is failing but I really don't want that to be the case.
Old May 31, 2025 | 08:20 PM
That could be it. You check the fuel pump and fuel filter while you at it? I'm reading the repair manual and trying to derive what else it could be.
From the manual
From the manual
Old Jun 1, 2025 | 06:14 AM
int3414's Avatar
int3414 is on a distinguished road
probably not helpfull,but i have a 98 jimmy with 200k,just did the intake gaskets,put the old spider back in...runs fine..if you ever upgrade the spider,youall see what a PAIN in the *** they are....did you try looking at it running in the dark,looking for any arcing?
Old Jun 1, 2025 | 09:31 AM
GeorgeLG's Avatar
You need to start with the fuel pressure leak down test. Then check your EGR wiring, voltage and ground.
George
Old Jun 7, 2025 | 09:29 PM
Update?
Old Jun 7, 2025 | 09:33 PM
Cbartee2's Avatar
Originally Posted by TheJimmyMan
Update?
I ended up selling the blazer as everything checked out and it got too much lol. Thanks for all the help everyone!
RenegadeBird01
Oct 12, 2022 12:36 PM
kodiak1
Oct 26, 2013 07:25 AM
93RRC
May 17, 2009 01:42 PM
phatskier20
Jul 25, 2008 01:46 PM
phatskier20
Jul 18, 2008 03:58 PM
