99 blazer 4x4 wont work
Old Dec 24, 2019 | 06:41 PM
Gage Hazelett's Avatar
Gage Hazelett is on a distinguished road
Default 99 blazer 4x4 wont work
Hi my 99 blazers 4x4 isnt working the only button that lights up is the 4x4 and it flashes a couple times then fades out any ideas on how to fix it?
Old Dec 25, 2019 | 12:58 AM
Look for threads on vacuum leaks and transfer case control modules (TCCMs). Those are the two places to start. Look for the symptoms for failure of each.
Old Jan 22, 2020 | 05:34 PM
FletcherTime's Avatar
FletcherTime is on a distinguished road
So if you go under the hood, near the firewall there's a vacuum switch in the center. One of the lines goes to your 4x4 vacuum actuator under your battery tray, The other goes to (if I'm not mistaken) the intake manifold and connects to a little port on the PCV hose. Inspect the lines and the actuator itself for holes and cracks.
My lines had holes all down it and dry rot. If that's the case for you, that's probably your problem. If it is, I would also check the vacuum lines for your HVAC system which is towards the firewall on the right fender (if you are viewing from the grill) right behind the ABS control module.
Here's a pic of one of my lines:
All my lines were like this because the factory heat shield is garbage.
Here is a quick guide on the locations I'm referring to:
However you should note that I own a 2001 Blazer LT with the 4 button 4x4 switch (Auto 4WD, 2HI, 4HI, and 4LO)
Tinted
Nov 30, 2011 02:07 PM
evader68
29
Dec 15, 2010 02:15 PM
jimmy979
Feb 28, 2010 09:14 PM
s10skookblazer
Mar 22, 2009 06:37 PM
blazerrider101
Jan 6, 2006 11:11 PM
