'99 Blazer S10 wierd electrical problem
Old Oct 23, 2010 | 05:36 PM
Manning's Avatar
Manning is on a distinguished road
Exclamation '99 Blazer S10 wierd electrical problem
Just today my Blazer started giving me trouble when I try to start it. This morning it started fine, but later on in the day, I tried to start it up again and it went crazy. It sounded like the battery was dead - clicking, trying but not quite able to turn over, all the lights on the dash come on, and here's the weird part.. it pops open the rear gate. Luckily, it only took me two or three tries and the engine turned over and I got it home. It runs fine once started.
I was wondering if anyone heard of a problem like this or has any suggestions on what it could be. Thanks a lot.
Old Oct 23, 2010 | 05:51 PM
b1heqh54's Avatar
b1heqh54 is on a distinguished road
I'm afraid I don't have any concrete input other than it sounds like the opening scene to another bad Paris Hilton horror film....maybe the ignition switch or the Body Control Module? When it finally started and you drove away did you look in the rearview? Maybe Freddie or Jason was just about to pull open that rear gate. Good Luck, I'm sure someone else on here will be be able to give you some help.
Old Oct 27, 2010 | 07:55 PM
bob gould's Avatar
bob gould is on a distinguished road
i have a 1997 and had similar problems,it was the connection underneath the ignition switch,have to take the bottom shroud off the column and there is a black box looking connector with about 5 wires in there,it was one of those wires that had a bad connection...it wont start until you get power to light up the dash,it will turn over but not start...
Old Oct 27, 2010 | 09:32 PM
OO-Jimmy's Avatar
OO-Jimmy is on a distinguished road
assuming you checked the battery terminals? i had the same problem, loose battery, id say start there if you havnt already
dailydriver
Nov 5, 2012 06:38 PM
rabbit0102030
Mar 26, 2008 07:35 AM
5brown1
Dec 21, 2007 08:47 PM
zipper_018
May 20, 2007 12:45 AM
Jared
Oct 18, 2006 05:38 PM
