ABS pump/ module bypass
Old Dec 13, 2022 | 09:30 AM
topdawguide's Avatar
topdawguide is on a distinguished road
Exclamation ABS pump/ module bypass
I have a 1997 GMC ZR2 Jimmy. I was diving the other day and when I hit the brakes only the left front tire locked up. it's like the abs system started to work and then locked up. Now on the left front brake works. I have taken the right front line loose from the abs module and no brake fluid comes out. I really just want to do away with the abs module. I looked at a few different proportioning valves but can't seem to find the right one. I need help figuring this whole thing out. The primary use for this vehicle is off-road.
please help
Old Dec 13, 2022 | 09:50 AM
I used one I bought from Summit Racing that, IIRC, was for a Camaro with front and rear disc brakes. I think it cost about 50 bucks.
You can use lots of different ones. The most important consideration is the rear brake configuration (drum or disc).
Old Dec 19, 2022 | 08:36 AM
Just trying to figure out what I need to do with the brake lines if I go this route. I'm pretty sure I will need some adapters to make it work with the original brake line fittings.
Toocute350
Jul 17, 2020 02:49 AM
tycobb280
Aug 8, 2015 10:18 PM
beastbandit92
Aug 13, 2010 08:24 PM
88beast
Mar 22, 2010 06:54 AM
BIG-RED
Nov 6, 2009 06:52 PM
