air conditioning
Old Aug 22, 2013 | 02:29 PM
jim baird's Avatar
jim baird is on a distinguished road
Default air conditioning
AC blows 75 degree air...yesterday blew cold.
Under hood see line of thrown "grease" or something on hood under wrap. what gives?
Old Aug 22, 2013 | 05:43 PM
BlazerRazor's Avatar
BlazerRazor is on a distinguished road
Did you check all of your connections? Lines, etc?
Old Aug 22, 2013 | 08:18 PM
Is the grease directly above the compressor? If so, the front seal needs replacement. If you still have the OEM Harrison HT6 compressor, you might want to consider a Sanden compressor, MUCH better design.
Old Aug 23, 2013 | 09:39 AM
jim baird's Avatar
Thanks for replies...Razor, I am not a mechanic. I had the AC overhauled 2 yrs ago, I think with new compressor...Hook, yes. A thin line right above the belt. Does it mean less than new compressor?
Old Aug 23, 2013 | 09:28 PM
Classic symptom of the front seal leaking. It can be repaired, but with parts, refrigerant, & labor, plus the fact that the case seals are a poor design, probably be less expensive, and better in the long run, to install a Sanden compressor. They bolt right on, no modifications necessary.
kinson33
Mar 29, 2010 07:10 PM
DCFluX
May 16, 2008 09:20 PM
KaptainKen
Mar 23, 2008 05:03 PM
DCFluX
Oct 5, 2007 06:28 PM
myboo11009
Aug 22, 2006 04:21 PM
