Almost have a 99' Blazer...
Old Dec 4, 2013 | 01:30 PM
Tuna's Avatar
Tuna is on a distinguished road
Default Almost have a 99' Blazer...
Can someone explain what the code PO147B indicates and perhaps the required fix options?
Also, why would there be a fluid leak from the tranny output gasket on a recently rebuilt transmission? Is this a common problem with Blazers?
Old Dec 6, 2013 | 02:14 PM
abig84's Avatar
out gaskets seem to leak on almost every vehicle i see. i have a few trucks and even after replacing them they seem to instantly leak no idea why so i just ignore it.
P0147 Heated Oxygen Sensor (Bank 1 Sensor 3) Heater Circuit Malfunction
Possible CausesSetting Conditions
  • HO2S heater ground circuit is open or has high resistance
  • HO2S heater power circuit is open (test O2S fuse in fuse block)
  • HO2S heater element has failed
  • PCM has failed
Old Dec 7, 2013 | 12:31 PM
Tuna's Avatar
Default PCM failed??
Ok. What is a PCM? How can it fail?
kmartin
Oct 3, 2014 09:54 PM
brokenline
Jun 29, 2010 10:11 AM
Nilyjo
May 22, 2010 12:17 AM
bluiewest1
Oct 24, 2008 04:26 PM
havrelm1
Nov 20, 2007 04:15 PM
