anyone instaled HID head lights on a blazer
Old Dec 20, 2007 | 01:25 PM
  #101
mdehoogh's Avatar
Default RE: anyone instaled HID head lights on a blazer
i dont think the projectors will use a 9006 lowbeam bulb. from the pics of drperry's it looks like his needed H1's to fit in the projectors. i dont know too much about the projectors so maybe some more people will be able to answer all your questions. but definately buy the projectors before the HIDs. my brother in law ordered HIDs and projectors for his Jetta, the HIDs came right away but the company he ordered the projectors from was out of stockand a month or two later, they finally sent them. it turns out the projector uses a different bulb than the HIDs he bought. its too late to return the bulbs so hes just gonna have to buy another set of HIDs
Old Dec 20, 2007 | 02:42 PM
  #102
quinnman105's Avatar
quinnman105 is an unknown quantity at this point
My buddy has installed them BUT not on a blazer. He has them on his dodge.
Old Dec 20, 2007 | 03:08 PM
  #103
drperry's Avatar
The projectors will use your current 9005 headlights... And come with H1 bulbs for the low beams...
Most likely, anyway.
As for hurting the halos... Mine still work great! And they've been like that for a few months now...
To get the HID's to fit in the projectors, you're probably going to have to do some trimming... I hope you've got a dremel! lol
Old Dec 20, 2007 | 10:55 PM
  #104
davtak's Avatar
The pic of the headlights on the ebay page show a bulb in the highbeam housing in the middle of the halo. That's the 9005 highbeam bulb I have now? The low beam housing is the reflector housing or the halo socket? The lows go on the outside in the reflector housing, correct? Did yours come with the H1 bulbs needed?
See, now these have the halos around the low beam bulb and the ones that I am looking at have the halos around the high beam bulb. I like the halo around the high beam bulb because the fact that I don't have the high beams on all the time and can have the halos on with the low beam bulbs at night. How do you wire up the halos as the DRL's or can you?
Old Dec 21, 2007 | 05:35 AM
  #105
drperry's Avatar
Mine came with bulbs for the projectors, which were H1s... I think it's probably the same base company that makes them...
It will probably use your current highbeams, and come with it's own lowbeams.
And I'm sure there's a way to rig the halos to come on with the DRL's... or at least wire it into an ignition controlled wire, and it'll be the equivalent... pretty much, lol. You just won't be able to shut them off without shutting off the truck.
Though, it'd be much easier to wire them into the park lamps, or signal lights...
Old Dec 21, 2007 | 06:03 AM
  #106
nj4x4blaze's Avatar
ORIGINAL: otnietdehoooo
i got the relay installed today. from what i can tell, it helps. before the relay, every now and then only one light would turn on or sometimes neither of the lights turned on. after the relay, i tried it and they both came on. about 10 minutes later i tried it again and they both came on. i keep running outside every 15 min or so to check and they both turn on. the relay goes from a single headlight harness and plugs into both ballasts. that way when one headlight is on, both are on. the relay draws power directly from the battery instead of running power through the stock wiring harness.
ORIGINAL: drperry
Are your daytime running lights your highbeams or lows?
Mine were the highbeams... I know it worked after I did the DRL mod under the hood, and it brought my highbeam DRL's back...
my DRL's are my high beams at half power.
when i tried the quadbeam mod, i followed Kyle's How-to step by step but it didnt work. its not that big of deal though, i rarely use my highbeam.
i recently disabled the automatic headlights and i like it better with manual control
It's good to hear your HID's are running fine now. RELAY KITFTW!!!!!!! lol
Old Dec 21, 2007 | 06:12 AM
  #107
drperry's Avatar
Yeah, but I still had to take my relay out
It's the quadbeam mod that did it, lol.
I've got a good idea how to fix it, too... just gotta run wires to the headlight switch... and I can my quadbeam relay to power the HID's, as I'll just use the headlight switch itself to trip the relay... Then the lowbeams are independant of the highbeam control stick...
Old Dec 21, 2007 | 09:05 AM
  #108
nj4x4blaze's Avatar
You should do a How To.
Old Dec 21, 2007 | 03:43 PM
  #109
drperry's Avatar
If I get a warm enough day, so I'm not in the garage freezing my nuts off while doing it, that's what I'll do, lol.
Old Dec 23, 2007 | 11:51 AM
  #110
davtak's Avatar
I found a video showing the halos blinking with the turning signlas. It looks pretty cool.
http://www.youtube.com/watch?v=bcmoR9OO5L4
