ATF or Diff-Gear oil?
Old Sep 17, 2020 | 04:35 AM
go chevy's Avatar
Default ATF or Diff-Gear oil?
Does it matter which you use in a Transfer Case, auto trans fluid or diff/gear oil? I have a 98 Blazer LT 4x4... I can't seem 2 find what I am looking for on youtube so I figured I would find out what I need 2 know from you folks, thanks.
Old Sep 17, 2020 | 11:34 AM
Hadyss's Avatar
I was told u can use atf but if u have the 4-button tcase then it has to be the gm autotrak fluid
Old Sep 17, 2020 | 11:39 AM
Agreed. DO NOT use gear oil!
Old Sep 17, 2020 | 10:44 PM
go chevy's Avatar
I have the 3 button switch on the dash... So ATF is ok 2 use then or should I use Diff/Gear oil?
Old Sep 17, 2020 | 10:46 PM
go chevy's Avatar
ATF it is then... Thanks for the help
Old Sep 18, 2020 | 06:20 AM
I was mistaking the 2 again... never swapped out that fluid yet...
Old Sep 18, 2020 | 12:12 PM
You're welcome.
To elaborate a little, your transfer case has an oil pump that lubes it. Gear oil is too thick for the pump to properly move.
Old Sep 18, 2020 | 12:15 PM
Hadyss's Avatar
I had to find it all out as I got into an argument with my uncle saying I could put stuff in all transfer cases and had to prove the 4 button auto cases use autotrak and the non auto is atf
Old Sep 18, 2020 | 08:48 PM
Your owners manual will list it or you can call a GM dealer with your VIN and they will tell you what you need.
Especially for the Auto 4wd transfer cases (4-button), you can danage tee transfer case unless you put in the correct fluid.
Old Sep 19, 2020 | 10:44 PM
go chevy's Avatar
I have the 3 button switch on the dash... So ATF is what I need
jumpinjimmy
Apr 3, 2014 09:48 PM
danmiranda
Jun 5, 2010 11:03 AM
MagnumRulzes
Feb 25, 2009 05:13 PM
portcqb
Apr 27, 2008 08:24 PM
kleijaker
Oct 24, 2007 06:08 AM
