Down the Rabbit hole
Old Sep 15, 2020 | 07:20 PM
kc8oye's Avatar
kc8oye is on a distinguished road
Default Down the Rabbit hole
wowsers, what a fuster Cluck! i bought a 94 s10 blazer.. for $400.
it had leaky fuel lines near the tank... one look at those lines and I knew the second I touched them, they were going to snap off.
I got ahold of a place called www.linestogo.com and for $180 they sent me both the pressure and return lines in pre-bent steel, along with the stainless braided flex lines (and fuel filter)
after a miserable time of getting the tank out, the supply line snapped right off when i lowered the tank.. but since I played it smart, and ordered a new fuel sender unit too, I just cut the lines off with an air saw and didn't' have to deal with trying to get the fittings apart.
then while I was cleaning the tank up getting it ready for a quick coat of paint, I discovered it had pin holes in it just above the 1/2 tank point.. that would have REALLLLLLY P'd me off if I had got it all back together and not discovered that until the first time I put $50 worth of fuel in it!
so I ordered a brand new tank from Spectra from RockAuto.com ($62)
I ordered a brand new fuel sender assembly too.. ($30)
then I figured I'm in it this far, went ahead and put a new Bosch fuel pump in too, ($80) the truck only has 98k miles.. but I figured why not?
I got lucky with the front fittings.. even tho they're in a nightmare of spot over the top of the transfer case drop, sandwiched in next to the torsion spring cross member... I soaked them in PB blaster, several times a day for a week, waiting for the heat/humidity to break.. and they came apart with surprising ease!
Then, I discovered, someone had removed this tank b4.. the upper, driver's side strap was not re-installed.. no real surprise.. it made putting the tank back in a real joy, as the steel lines have to come over the top of the strap, not leaving a lot of room to get in there to connect the lines.
So.. i ordered new straps from Amazon (They were cheaper when i factored in RockAuto's kind of expensive shipping costs)
then to top it all off, I discovered the ground strap for the filler neck was missing too.. so I had to get creative to re-create that, as I didn't want to buy another
almost got this blasted tank back in.. then I discovered where I cut the filler neck vent hose ... it was too short.. thankfully my local o'rileys had 5/8" fuel line on a roll.. with some help from the heat gun, I managed to re-create that tight 90° bend without it kinking..
finally got it all back together! spent way more than I wanted too.. but at least I know the fuel system is solid!
I'll post some pics when I take the time to get them off my phone and onto the PC!
Old Sep 15, 2020 | 07:54 PM
Well with the lack of worries on that end, could be a good time to take it for a long haul, see any other issues...
Old Sep 15, 2020 | 08:05 PM
2001ZR2's Avatar
I hope Spectra works better for you than I
My Spectra filler neck after a month the anti siphon ball was swollen to the point that it blocked the filler
Old Sep 15, 2020 | 10:50 PM
Wow. Congrats!
Then again your truck is 26 y.o. and depending on where it lived most of its life, the environment could have been pretty tough on it.
I had 92 up until about 10 years ago and I had to have a new fuel pump put into it. It cost me $500 about 15 years ago.
If I had a fuel pump issue now on my 99, I'd do it myself but I'm going to do my best to avoid that by never letting my tank go below 1/4 full if I can help it.
Old Sep 19, 2020 | 04:51 PM
kc8oye's Avatar
My buddy uses only Spectra tanks in his restoration shop.. never had any issues with them. I kept my factory filler neck!
Old Sep 19, 2020 | 04:56 PM
kc8oye's Avatar
yeah.. it's gonna have to wait until I can afford plates and insurance for it.. and it has a laundry list of little things that need adressing.
needs new windshield
high/lo beam switch gets stuck in the high beam position.
hot/cold selector doesn't work, (currently stuck in full hot)
4x4 switch is 100% inoperative. (4x4 works, just not the switch)
driver's side window likes to roll forward instead of going up
it rides like a hay wagon.. ( I need to make sure someone didn't crank the torsion bars up for a cheap lift)
it may need a front seal on the transmission
temp gauge in the dash doesn't work (it's the gauge, computer shows correct temp on the tech1)
needs a driver's side ebrake cable (it was cut)
probably never had a full 4x4 service either.
it has a random misfire that needs looking into.
at least the 4l60e seems happy enough.
i addressed the fuel lines first since I like to put safety issues first.
Old Sep 20, 2020 | 06:02 PM
Oh boy... seems like you go your list down. Hope it goes easily. Best of luck, let us know how it goes.
Old Sep 21, 2020 | 04:35 PM
Sounds like you know your ways around cars. Good luck with the fixes and hope you have it on the road soon.
Smc
Nov 14, 2013 04:46 PM
Nick_K5_Blazer
Jan 18, 2011 06:35 PM
Hey Blue
Feb 7, 2009 08:18 AM
Jman
Nov 13, 2006 10:58 PM
h123hop
Jan 16, 2006 12:24 AM
