Bad start
Old Jun 27, 2022 | 11:58 AM
BritishColumbiafishing's Avatar
BritishColumbiafishing is on a distinguished road
Default Bad start
Not starting on first crank maybe 3, 4 or 5th, I have lead to believe is a ignition issue, , I have done the spark plugs, lead wires, ignition module, crank sensor, and still not staring great, started to misfire also on a long haul trip...fingers are pointed towards the distributor.?
it's a 2002
any help or input would be great
Old Jun 27, 2022 | 01:00 PM
El_Beautor's Avatar
Did you use OEM or high quality replacement parts when doing your tune-up?
I think you're right that it may be related to the ignition system, but just to eliminate it, have you done a fuel pressure test? These trucks are quite specific on the required fuel pressure. There's detailed instructions on how to do the fuel pressure leak-down test in the How-To section.
Old Jun 27, 2022 | 01:23 PM
a fuel pressure test has been done around 5 months ago, I do have an engine light on that is evap sensor. But I have replaced most of them recently. I used bosche iridium spark plugs not oem
Old Jun 27, 2022 | 04:40 PM
Fixed er up, and she runs great now, it was a bit of a bitch, I removed the cap, then the rotor with ease, went to go put back in the new rotor and the t15 female thread stripped due to old worn metal, I thew a big glob of leak lock on, let it dry and tried it out...bad idea. Had to.buy a new rotor as the set pins snapped off the bottom, got the oem one threw in a t20 on the rotor on the stipped side and it was sitting in very tight. Got her all back together and we are all good now!
running good again
Old Jun 28, 2022 | 09:56 AM
El_Beautor's Avatar
Excellent. Glad you were able to find and resolve the problem, and thanks for sharing what you found.
I ran into that same issue when I replaced my intake manifold gaskets. I rebuilt the tab with JB Weld and a nut.
Cjp p
Jun 11, 2023 01:20 PM
Simplechevy
14
Jan 1, 2021 06:43 AM
Spencer Grow
Nov 26, 2018 12:20 PM
error_401
Mar 5, 2015 09:49 AM
Halberg17
Sep 13, 2014 02:15 PM
