Basic 4 Wheel Drive Maintenance
Shifter on the floor is an NV231 and uses DexronVI. The Bravada has a NV136 single speed transfer case. It has a clutch pack and an oil pump inside. He's asking for trouble if it hasn't been changed. It takes a special fluid available only at a GM dealer. Should be changed at least once a year.
Thanks for the transfercase help. Now I know what kind I got. And I didn't have to go out in the snow crawling under a muddy truck. THANKS
I will mark this up in the manual for maintenance.
This chart explains the NP/NVG numbering system: http://www.jameshalderman.com/images...p_chart_NV.pdf
Check your owners manual for service interval. If you don't have one, Google search it and download a pdf of the manual, it's free. Rule of thumb, no more than 50K miles. Manual & 3 button electric shift cases, (231 & 233) use DexronVI. Single speed Smart track/Auto track cases, (136 & 236) use Auto Track II fluid ONLY, there are NO substitutes:
Fluid change takes less than 30 minutes, no filters to fool with, and under $20 in fluid. No excuse for destroying a $1K transfer case
mirrorimij
Jun 8, 2019 03:34 PM
awd, blazer, chevy, drive, front, general, maintenace, maintenanace, maintenance, performance, shaft, smartrac, turning, wheel
