Bell housing bolts
Old Oct 22, 2020 | 10:40 PM
Marshp55's Avatar
Marshp55 is on a distinguished road
Default Bell housing bolts
Curious if there is a trick to getting the bolt on drivers side right, the one right against the firewall. Tried ****ing around with a universal and prying it over with the engine mounts undone. Any tips would be great.
Zr2 I picked up for 100 bucks
Old Oct 23, 2020 | 11:33 AM
LesMyer's Avatar
3 ways:
1. remove the transfer case and lower the back of transmission
2. cut a small flap in the floor behind the accelerator pedal and bend it back when you are done
3. raise the body
All three will work. I chose #2 on mine. #1 and #3 are just too much work IMHO.
Old Oct 23, 2020 | 12:13 PM
Marshp55's Avatar
Default Thanks for the reply
Ya that’s what I was thinking I’m wondering if I will be able to get at the top left by removing the manifold and y pipe and heating a 15mm wrench with a torch and bending it to a degree to where I can get ahold of it
Old Oct 23, 2020 | 07:08 PM
eshaw's Avatar
I'd raise the cab.
Old Oct 24, 2020 | 12:26 AM
Marshp55's Avatar
Default Update
Did not have to raise the cab or lower the trans took my intake off and just worked the bolts with a custom bent wrench.
Old Oct 24, 2020 | 06:54 PM
eshaw's Avatar
That would be a pain also. You'd have to disconnect the heater hoses and upper radiator hose, plus pull the distributor.
ldawg1346
Jan 12, 2015 01:16 PM
Woober
Aug 2, 2009 07:13 PM
sjogrenzr2
Feb 12, 2009 06:32 PM
SCOTTY
Apr 15, 2008 02:54 PM
95Blazer4x4
Mar 7, 2008 07:54 PM
