Blazer LT 4x4 1999 motor/trans same as 2000 motor/trans
Old Feb 28, 2008 | 07:10 PM
rob1621's Avatar
rob1621 is an unknown quantity at this point
Default Blazer LT 4x4 1999 motor/trans same as 2000 motor/trans
So my reverse gear went out so i am planning on changing the whole motor and tranny, and i found a 99 tranny/motor for a good price and am just wondering if it will fit my 2000 4x4 blazer? i need to know this within an hour so please let me no ASAP! thanks
Old Feb 28, 2008 | 08:00 PM
WolfPack's Avatar
Default RE: Blazer LT 4x4 1999 motor/trans same as 2000 motor/trans
YES! The only change from 99-00 was heavy duty suspension for 4x4s (Bilsteins) and LMC says enhancements for a 'smoother, quieter running'. Everything should hook right up though!
Old Feb 28, 2008 | 08:31 PM
Same transmission!
Old Feb 29, 2008 | 11:52 AM
rob1621's Avatar
ok well i might have found a 98, but i called the dealership, and they said, yes, physicaly they will fit, but they could have diffrent computer settings or something like that. so if i get the 98 could i just take out the 2000, and put in the 98, and it will run fine?
Old Feb 29, 2008 | 12:00 PM
rob1621's Avatar
also what about a 97 transmission, can i take out teh 2000 and put in the 97 and have no problems? i need help really fast!!!!!!!!!!
Old Feb 29, 2008 | 08:15 PM
I believe the transmission in the '97 has a one piece case. The '98+ has a two piece case with a full front bell housing. The oil pan in the '97 is stamped steel while the 2000 is aluminum.
kamilkowalski
Apr 30, 2015 08:36 PM
mikepro
Aug 15, 2011 07:03 PM
Paul-ish
Jul 21, 2011 10:53 AM
AmberRose
Aug 30, 2010 08:58 PM
m.sterner
Nov 29, 2009 10:34 PM
