Blazer Sluggish After Mpfi Upgrade
Old May 26, 2022 | 12:57 PM
Tasmick's Avatar
Tasmick is on a distinguished road
Default Blazer Sluggish After Mpfi Upgrade
My blazer has gotten more sluggish after replacing the spider injector assembly. When I'm accelerating to merge into the highway it is a lot slower. The car runs fine otherwise. Any ideas of what it could be. I've checked fuel pressure air and ignition the inside of my engine was extremely clean.
Old May 27, 2022 | 12:28 PM
GeorgeLG's Avatar
Do you have a scanner that can look at live data? If so let’s start with fuel trims.
Did you change the fuel filter
George
Old May 27, 2022 | 02:26 PM
Are you sure you put all the injectors in the right ports? IIRC, two of them need to be crossed, which can be confusing.
Old May 27, 2022 | 05:50 PM
Tasmick's Avatar
Default I'll try to get some live data photos soon
George
I should be able to get some live data over the weekend I'll be sure to post pics if I can!
Old May 27, 2022 | 05:52 PM
Tasmick's Avatar
Default I made sure to cross it correctly
I watched around 10 different videos online as well as read the instructions and made sure the numbers corresponded from the spider injector to the engine ports I also make sure that they were completely seated.
rockjock29bc
83
Aug 1, 2019 07:26 PM
PuckinBlazer
Aug 12, 2017 08:39 AM
el8232
Dec 18, 2008 08:32 AM
vagnozzi
Nov 17, 2008 03:30 PM
