'Rebuilding' Updated MPFI fuel spider assembly??
Old Aug 11, 2017 | 06:18 PM
PuckinBlazer's Avatar
PuckinBlazer is on a distinguished road
Default 'Rebuilding' Updated MPFI fuel spider assembly??
So, I got a MPFI spider unit from a friend's 2003 Astro that was totalled in the rear end but ran fine previously. I want to put it in my 2000 Blazer that still has the old poppet CSFI unit. I checked the injectors ohm resistance and tested function with a few AA batteries stacked together.
I want to replace the O-rings and plastic tubes on the injectors, but cannot find replacement parts for the newer unit anywhere! Only for the old style.
any advice?
Thanks!!
Old Aug 11, 2017 | 07:41 PM
rexmburns's Avatar
Super Moderator
As long as I've been in this and other forms I've never seen a single person rebuild a spider.
Old Aug 11, 2017 | 08:48 PM
I dont see why everyone buys brand new assemblies for $200+ when used MPFIs are a dime a dozen at scrapyards. And you're right, I've searched thoroughly with a bunch of different combinations of keywords and can't find anything. Perhaps folks are too lazy to spend half an hour removing used ones to chance it. Everything checks out with this one, and it's 100% free. I'm going to throw it in and i'll post the results.
Old Aug 11, 2017 | 11:27 PM
Spray it down with starter fluid to clean it and throw that joker in. I don't think there's any "rebuilding" of the spider injector...
Old Aug 12, 2017 | 07:53 AM
newguy's Avatar
because I only like doing the job once
Old Aug 12, 2017 | 08:39 AM
You've checked that the injector is electrically sound, but not that it has a known and consistent spray pattern. This is not done as you typically have no idea of the age, usage, or fuel quality used in the assembly pulled from a junk motor and are taking a chance on wasting hours of time involved in the process of removing and installing your "rebuilt" injection spider.
I used quotes on rebuilt as the process you describe does not rebuild anything, just reassembled with parts of unknown mechanical health. Rebuilding denotes a process of actual restoration of the functional parts. In this case, the functional parts that have not been reconditioned are the nozzle & seat components inside the individual injectors which are instrumental in fuel delivery.
Do not attempt to replace the lines that run from the metering block to the injector. They are not available except on new injectors. Incidentally, new injectors bought individually cost more than a complete injection spider.
Jefflego
Jan 17, 2023 02:34 PM
Shawnf92
Dec 9, 2016 01:57 AM
ChevOeat
14
Nov 21, 2011 01:33 PM
midnightbluS10
Sep 3, 2009 03:24 PM
gw2009
Jan 12, 2009 05:04 PM
