blazerforum road side assistance please
Old Dec 4, 2013 | 07:25 AM
Badco's Avatar
Badco is on a distinguished road
Default blazerforum road side assistance please
I'm on the side of the highway. yuppie.
I had the subs thumping and the song ended, then my Rpms just starting going haywire along with my voltogauge. it was a hefty stutter.
puller over and restarted the car fine. okay? go to drive. coasts fine until I give it gas. then the crazy happens. Rpms stutter about 700 to 19 and the voltometer climbs with every press of the gas until its past the 3/4 mark.
checked my wires, good. fuses on thedash look good. unhooked my posi to the amp and it still did it. belt looks fine.
the battery light isn't a flashing constant it looks more like bad ground. airbag flashes too.
Old Dec 4, 2013 | 07:38 AM
Badco's Avatar
I am idling fine on startup but only when I go into gear And throttle. the voltogauge rises with throttle. battery light flickers (nonconstant flash) and it went out.
Old Dec 4, 2013 | 11:10 AM
Badco's Avatar
coincidentally Ohio dots freeway service stopped right after and helped me out. alternator /voltage reg sound right to anyone? I made it off the interstate, pulled into a gas station and my truck acted as if nothing happened. not sure if I want to drive home though...
Old Dec 4, 2013 | 11:39 AM
dirt101's Avatar
dirt101 is on a distinguished road
sounds to me like to voltage reg has went out allowing the alt to charge higher, not really sure why that would cause a weird feeling on the gas. Possibly an odd idle but I cant say for sure.
Old Dec 4, 2013 | 01:07 PM
Badco's Avatar
seems like it was the increased rpms acting on the alt., overcharging and going in a loophole fail-safe. just a theory.
hear that? its the sound of my paycheck disappearing!
Old Dec 5, 2013 | 09:20 AM
El_Beautor's Avatar
That's an odd problem, but I agree that it sounds like your voltage regulator. Make sure you post back and let us know what the problem ended up being.
Old Dec 5, 2013 | 05:53 PM
Badco's Avatar
Everything is running smooth for now. After replacing the Alt & Tensioner last night my SES light disappeared. However the stutter on Stop&Go came back today. Not sure if it has to do with the rain.
Autozone has a volto reg but the review says it isn't a fit for GM vehicles. The only review, mind you but I hate to drop 35 bucks and it actually not fit. I'll try Rockauto if all else fails junkyard. As for now, I'm leaving the amp unhooked. When I get to the Volt Distro I'll do a big 3 and add another power cell in the back.
EDIT: If the voltage regulator was a separate component lol. Glad I got that over with.
Kim Kohrs-Reimer
Oct 5, 2014 09:25 AM
Wexinlo
Apr 6, 2011 11:35 PM
zombieblazer
Jul 8, 2010 09:47 PM
spankeytaylor
Mar 7, 2009 07:02 PM
Blazin 4x4
Sep 21, 2005 01:26 PM
