Broken seat recliner adjuster RHD vs LHD
Old Feb 1, 2009 | 01:25 AM
kiwiblazer's Avatar
Default Broken seat recliner adjuster RHD vs LHD
I've also posted this on GMTruckForum.net so if any of you guys have already seen it ... please forgiveme.
I wanted to repair the seat recliner lever this weekend. I was going to do the fix per the "how to" posted by 20Blazer00 back in May '07. (He had found it on the ZR2 site). I've now found that the one that came off was in fact the GM upgrade. That's why when I went to the Chevy guys it was the same as what they had in stock. I've checked the left side & that's the same as what I've seen on the forum - meaning that the drivers side had already been replaced. Problem here is the oe handle (pass side) sits about an inch above the other switch & on the drivers seat the upgrade is almost touching the lever - seems the keyways are in the wrong position. There is no evidence that the metal insert has moved. See pics.
Question I have is, fitting the lever back, the grub screw is at the furtherest point in & to get an allen key to it I somehow need to get behind the plastic seat suround. Looking at the "how to" I see the one being repaired (other than that it's a 2 door) does not seem to have this plastic panel. Is this an overseas option? or do your 4 doors also have it? Just curious!
tooth_dr
Oct 19, 2012 05:55 PM
kiwiblazer
Feb 1, 2009 01:36 AM
streblo
Sep 27, 2008 08:34 PM
cherryred4x4
Aug 1, 2006 03:50 PM
C5Longhorn
Feb 28, 2005 03:21 AM
