buyin new rims, need advice
Old Feb 10, 2009 | 12:42 PM
robbiegamble's Avatar
robbiegamble is an unknown quantity at this point
Default buyin new rims, need advice
im looking at buying a 15 x 8 with 4.5" bs. how much wider of a stance will i get like this? if normal bs is 6" then with the 4.5 i should stick out an 1.5" on each wheel right? but will it stick out any farther with an 8" rim?
Old Feb 10, 2009 | 12:51 PM
Default RE: buyin new rims, need advice
Stock rim width is 7" with 6" back spacing as you said. So backspacing alone you will gain 1.5" per side. Then with the additional rim width, you will gain another inch (because backspacing references the back surface of the rim). So you will be sitting at 2.5" wider per side or 5" overall width increase.
Be careful though. Pushing things out this much can cause interference with the fender/firewall.
Old Feb 10, 2009 | 05:13 PM
update: 30x10.50r15 interco super swamper radial on 15x7 rim with 4.5" backspacing works absolutely fine on a stock non lifted 95 blazer 4x4. i even drove it up a car ramp to test my articulation! no rubbing what so ever! now i just gotta get the other 3! lol. thanks everyone for there help!
Old Feb 12, 2009 | 07:06 AM
pathill's Avatar
pathill is an unknown quantity at this point
I am not a real handyman and not even crazy about tires and rims. But hey, have you guys checked out on the new trend? Black rims, they seem to be all over the place. Anyone?
Old Feb 16, 2009 | 08:47 PM
Blazercrazy's Avatar
Blazercrazy is an unknown quantity at this point
How far does it hang out from the fender? I'm wondering what to do for backspacing on my 91 heh
Old Feb 16, 2009 | 09:06 PM
bandidolenny's Avatar
I have black rimsbut they werenot my first choice. I special ordered my wheels in order to get the backspacing that I wanted and thats all I could find at the time for a decent price.
Old Feb 19, 2009 | 10:01 PM
Byte Stryke's Avatar
Byte Stryke is an unknown quantity at this point
For 4x4 s-10 Blazers you need to be VERY Carefull... as I have just found out... about your backspacing.
my 2006.. while having a BEAUTIFUL Stance with a 2x2 lift... now is having an issue or 2 with the 4inch backspaced wheels.
used to be that when I turned I rubbed the swaybar and frame. Now when I turn, I Rub on the outside... meaning the fenders.
so this weekend its going to be me, a cutoff saw and some hammer-time.
take into consideration tire size, design, width and lift before running out and grabbing those cool-a$$ Mickey Thompsons
247monster
Nov 2, 2012 04:41 AM
Keystoneguy91
Tires and Wheels
Oct 27, 2012 09:40 PM
hedgepig
Oct 17, 2010 10:18 AM
blazeron24
Tires and Wheels
Jan 28, 2010 02:26 AM
daniel010
Jan 13, 2009 06:29 AM
