a/c problems
Old Feb 13, 2013 | 05:36 AM
nolimits79's Avatar
nolimits79 is on a distinguished road
Default a/c problems
Have a 02 Blazer ls and somehow the A/C inline diode blew went to radio shack picked up a new one put it in and nothin tested the power and the ground and no power goin to the compressor, (A/C is full) if I run straight power from battery compressor kicks on but nothin if i put the diode in or bypass it. Checked the relays and fuses all good has anyone ever had this issue and what can I do to fix it
Old Feb 13, 2013 | 01:07 PM
Twip's Avatar
did you use something to test the fuse or did you just look at it? try putting a different fuse in. sometimes when they blow you cant tell just by looking at them.
Old Feb 13, 2013 | 01:39 PM
Diaita's Avatar
Bad pressure switch on the accumulator?
Aanenson
Apr 14, 2011 09:12 PM
upblazer95
Apr 4, 2009 08:27 PM
